• 19.11.2026, 03:45
Dundys
kryoM.2 evo PCIe 3.0/4.0 adapter
lundi 10 février 2020, 04:00
Anyone has personal experience with this adapter. I was looking at these two: Product #: 53246 and Product # 53223. If I'm not mistaking, one has clear plexi and the other doesn't and that's the only difference.
It would be for my sons new Samsung 970 Pro M.2 NVMe PCI-E Drive. What I'm wondering is, is that a single slot heat sink, hes got sound card, wirelesses card and GPU installed so there is only 1 slot left.:)
Ce message a été modifié 4 fois. Dernière modification effectuée par "Dundys" (10 février 2020, 04:04)
Hufeisen
lundi 10 février 2020, 18:45
The 53246 has two coolers, one on the top side and one on the bottom side. It is compatible with M.2 2280 SSD.
The 53223 has one cooler on the bottom side. It is compatible with M.2 2280, 2260, 2242 SSD.
Both of them fit in 1 slot.
Dundys
lundi 10 février 2020, 22:25
Thank you very much, this info was very helpful .
Dundys
mardi 11 février 2020, 04:56
Well I got some feedback from owners of the coolers and I have also seen some reviews on NewEgg I think I pass, at least for now. It seems there is an issue with the bracket been oversized and causing some issues.
There are few reviews on New-egg and some of them claiming the same thing. Surprisingly my nephew got one few weeks ago and he’s not to thrilled so I might go pay him a visit to see for myself, unless Aquacomputer has already corrected (if that is, or was the issue)
Maybe AQ can chime here and clear this talk regarding this supposedly oversized bracket
Ce message a été modifié 6 fois. Dernière modification effectuée par "Dundys" (11 février 2020, 06:24)
mardi 11 février 2020, 14:48
The bracket has been adjusted 1 year ago.
Dundys
mardi 11 février 2020, 16:06
Ohh, now, that makes a difference. Thanks for the info. I will order directly from you (AQ) to be sure I get the new one :)
