• 10.10.2026, 15:28
Vankrom
Want to be sure of something before I order my loop parts.
mardi 11 février 2020, 21:55
I am working on a water cooling loop and intend to use the D5 next. I will be using a total of 7 noiseblocker B12-P 120mm fans.
I am hoping that I can connect a splitty9 / splitty9 active to the D5 next and have the fans respond to accordingly.
Am I right in this assumption or am I missing something
Thanks in advance! :D
p.s is the d5 next compatible with the heatkiller tanks?
DRF
mardi 11 février 2020, 22:00
Hello i dont know if i understood your question but with splitty9 you distribute power + 1 single PWM signal for every slot and retrieve 1 Tachy signal back
Vankrom
mercredi 12 février 2020, 03:05
Just wondering if the D5 next will have enough power to run the 7 fans or if i need the boost granted by the splitty9 active.
kandrey89
mercredi 12 février 2020, 03:35
https://www.blacknoise.com/datas/downloa…0_122012_de.pdf
B12-P has 1.92W consumption, so 7*1.92=13.44W and you have 25W fan power. So yes D5 Next should be able to power your fans!
ehupp01
mercredi 12 février 2020, 17:51
Had mine setup with 8 fans and they could not reach full RPM so I added a Silverstone 8-Port PWM Fan Hub and it works great. I think the splitty9 would be a good choice also.
Vankrom
vendredi 14 février 2020, 19:39
Was that a regular or the "active" splitty9?
ehupp01
samedi 15 février 2020, 16:00
Did not use Splitty9 I used the Silverstone 8-Port PWM Fan Hub that is similar to the Active it is powered. :thumbup:
Ce message a été modifié 1 fois. Dernière modification effectuée par "ehupp01" (15 février 2020, 16:02)
Vankrom
mercredi 19 février 2020, 00:21
Not got any experience with Silverstone products. Reliable?
ehupp01
mercredi 19 février 2020, 20:29
So far so good. First one I owned as well. :thumbup:
