• 12.11.2026, 18:09
smud
kryoM.2 difference between two water blocks
lundi 17 février 2020, 00:50
https://shop.aquacomputer.de/product_inf…roducts_id=3401 <- which plated this one?
https://shop.aquacomputer.de/product_inf…roducts_id=3408 (nickel plated water block)
I didn't find information about https://shop.aquacomputer.de/product_inf…roducts_id=3401 , seems it's copper by images but I wonder why it's cheaper than nickel then? I though copper has better heat sink than nickel or?
lundi 17 février 2020, 05:08
I believe both are copper, the nickel version has a nickel plating applied, hence the additional cost.
smud
lundi 17 février 2020, 15:39
Isn't it pointless to do then - adding nickel over copper since copper has better heat sink? 8| ?(
eisbehr
lundi 17 février 2020, 15:55
Some like silver plated coolers more than a copper surface. ;)
And the plating protects the copper for oxidation.
lundi 17 février 2020, 16:47
What eisbehr said... plus, the heat transfer lost across the very thin nickel layer is minimal.
But, for the purist, aquacomputer does provide the naked copper option.
Many people have paint on their radiators, not an optimal solution, but an aesthetic trade-off.
It's all about personal preferences, capitalism at work :)
Hufeisen
lundi 17 février 2020, 18:08
Nickel plating is required if you want to use Liquid Metal as thermal paste.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Hufeisen" (17 février 2020, 18:10)
eisbehr
lundi 17 février 2020, 18:25
As we learn step by step, everything is there for a reason! :D
smud
lundi 17 février 2020, 18:54
I don't think what you can apply liquid metal for these M.2 water blocks :D
Discussions similaires
