• 29.11.2026, 00:50
stingray
2 pin led lights
vendredi 13 mars 2020, 05:17
in my new build i have like 5 2 pin led lights that i want to use,what do you guys use to manage 2 pin leds?
id prefer to control separately if possible
i have a aquaero's and 2 farbwerks but dont see where this is possible.
so how do you guys manage your 2 pin leds?
thx
vendredi 13 mars 2020, 10:40
The aquaero has two 2-pin PWM controlled ports that you could use. These ports provide 12V so check which voltage is required for your LED strips. If lower, you will have to use a suitable resistor to connect them.
To be able to use these ports you need two of these plugs.
