• 12.11.2026, 19:05
Endeav
Aquasuite Virtual Software Flow meter bug
dimanche 15 mars 2020, 06:48
Hello, I own a Barrowch flow meter. It provides an RPM output which you divide by 86 to obtain a LPM reading. I am trying to set up a virtual software sensor in Aquasuite to do this conversion, which I can do successfully.
However, when I try to add this virtual sensor to the Quadro software sensors, it shows up as a non-unit sensor showing 4900-5100 output value, instead of displaying either a LPM or GPM reading from that selected sensor.
mercredi 18 mars 2020, 14:16
Hi, i can confirm a bug. But this is only a display error. Thr read back value from the aquasuite has no unit. In the next relase this is fixed.
Endeav
vendredi 20 mars 2020, 20:24
Hi, you can see it reads back 4904 with no unit, it should read back 2.2 gpm, or whatever that is in lpm.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Endeav" (20 mars 2020, 20:33)
vendredi 20 mars 2020, 20:54
The aquasuite works with liter per hour.
2.2 gpm == 490 lh
4904 / 10 == 490,4 l/h --> 2.2 gpm
pgm is a unit that makes in a normal water cooled system no sense. gph or use liter/h or l/h.
This is the unit used in 90% of the world. Gallons and inches are its 100 years no longer state of the art.
Liters and meters are SI units.
Endeav
samedi 21 mars 2020, 02:11
2.2 gpm == 490 lh
Didn't realize the 4904 was a conversion of the 2.2 GPM. That explains that so thanks, I thought it was some random number.
In most english language watercooling reviews such as thermalbench and xtremerigs, GPM is used so its easier for me to visualize using GPM, I live in Canada and we use SI units as well.
Bartdude
lundi 23 mars 2020, 05:48
Its also worth noting that the reviews you mentioned use US Gallons and not Imperial Gallons. Quite a bit of difference. I can remember using those same reviews to work out LPH so I could set my pumps accordingly.
