• 06.10.2026, 19:23
bmxer4l1fe
BUG REPORT: Aquaero Software Temperature sensors - recieves incorrect value from D5 NEXT pump
mercredi 18 mars 2020, 03:11
software sensor based on D5 Next Pump, value does not read and sits at default of 50c. Sometimes i can restart the Aquasuite service, but its not 100% consistant.
cptninc
samedi 28 mars 2020, 16:46
This just happened on my setup as well. I had two pumps which were both reporting correct values last night and now only one of them does. The odd part is that when I click on the pump in aquasuite, it shows the correct temperature - but nothing else can read it. I have tried restarting both the computer and the service without any luck.
lundi 30 mars 2020, 08:38
Post screenshots from your settings.
Pump and aquaero.
When you have an AMD Ryzen based system, try another USB port.
