• 29.09.2026, 10:29
helplessn00b
Flow sensor high flow orientation
dimanche 29 mars 2020, 21:07
Can somebody help me with this?
Is there any penalty (sound or accuracy) if I mount the flow sensor at 90 degree angle (fittings are facing up and down instead left and right). I know that the manual states that the best position is when the steel plate faces upward but in my case this is impossible to achieve.
Thank you very much.
bojer
lundi 30 mars 2020, 01:02
I had same problem. When I install perpendicularly this flow meter so you can her some clicking noise but when I install horizontally everything is OK. Just try found position in casefor horizontally position. If isn't possible found any position so ignore that noise :)
