• 19.11.2026, 04:25
lhdrive
Quadro + Splitty4 + Splitty4?
mardi 28 avril 2020, 01:46
Background
  • Currently successfully running a Quadro + Splitty4 for fan control, temp monitoring and RGB control
  • Four Corsair ML120 Pro RGB fans are connected to the Splitty4 Corsair RGB headers on the Splitty4
Question:
There is an Aquacomputer RGBpx out connection on the Splitty4; Can this be used to connect a second Splitty4 to add another 4 Corsair RGB fan connections?
If so, what additional cable is required not already supplied with the Splitty4?
eisbehr
mardi 28 avril 2020, 09:15
There is nothing mentioned in the manual, but as there is an "out" connection for RGBpx on the Splitty4, i think you can chain them. You will just need a RGBpx cable then. There comes one with every Splitty4, so you should have everything you need when you buy a new one. But if it is chainable this will probably only work if there are 4 fans connected to the first splitty. If there are only three connected this may not work.
mardi 28 avril 2020, 19:42
Right. You can chain them if they are conntected to a full set of 4 fans.
