• 22.11.2026, 22:05
j6runner
[Help] Fans not spinning all the way up under "Curve controller" mode (Aquacomputer Octo)
mercredi 10 juin 2020, 21:14
Hello,
I have an Octo with 4 Noctua fans (2x NF-A14 iPPC-2000 PWM + 2x NF-F12 iPPCF 2000 PWM), a Swiftech PWM DDC pump, and water temperature sensor probe
I have set in Aquasuite a custom curve for the NF-A14s and NF-F12s to increase speed based off of water temp. After a certain water temp, I have the controller signal 100% power output. However, the 140mm (NF-A14) fans only get up to ~1650 RPM with this curve set, even at 100% output. If I choose "Power preset" and do 100%, the RPM is ~1860.
I would like the fans to basically spin at max RPM when the curve is past a certain water temp but the 140s do not ramp up all the way with the custom curve. The 120s are fine.
Can anyone help me understand why even at 100% power output under the "Curve controller" the 140s do not spin up all the way?
Thanks!
mercredi 10 juin 2020, 21:41
This fans are not compliant with the Intel PWM Control standards, try other fans or contact noctua.
This is a fan issue.
mercredi 10 juin 2020, 21:52
THIS POST may be a little more helpful.
j6runner
jeudi 11 juin 2020, 19:56
Thank you for the info! Not a huge deal I suppose. I'll just set up automatic and manual profiles for times when I want to have the fans run at max speed, which can be done by just choosing "Power preset" and setting that to 100%
jeudi 11 juin 2020, 23:14
Or you could check with Noctua and see if they will send replacement fans to you :)
