• 12.11.2026, 08:02
mstern
Sharing Flow Sensor Data
mardi 14 juillet 2020, 05:46
I have a High Flow Sensor, a CPU block with Vision, and a D5 Next. All are connected to USB and basically working. I have Aquasuite set up and it's as impressive (or more!) than I'd even expected.
I can see the flow rate from my High Flow Sensor showing under its device ("mps") and can also see it under the the Overview Pages as a widget if I want to add it -- so far so good.
I can't figure out how to call up flow rate (from the High Flow Sensor) on any of the display screens on my CPU block or on my D5 Next. Seems hard to imagine this is not possible. They just show 0.0 l/h for flow.
Any advice appreciated!
mardi 14 juillet 2020, 07:14
aquasuite>Vision>display>Datenquelle>neuer Sensor>"mps"(High Flow, not d5)>Sensordaten>Flow
Hope this helps, and sorry I'm too lazy to look up the English names, but it should be a direct translation
ps: I think you must have at least AS file server running, if not the AS.
pps: have no "Next" but should work the same way
Ce message a été modifié 3 fois. Dernière modification effectuée par "EnigmaG" (14 juillet 2020, 07:47)
mstern
mardi 14 juillet 2020, 17:16
Thank you! That solved the problem on the (CPU block) Vision display.
I still don't see how to do similar on the D5 Next display -- if anyone else has a suggestion, I'd really appreciate some more help. I can add the High Flow Sensor as a data source ("D5 Next" -> "Sensors"), but I can't see how to change data sources in order to select it for any of its displays under "D5 Next" -> "Display".
mardi 14 juillet 2020, 18:19
Sorry i can not help you.
Thought there should be a display tab just like the Vision.
mstern
mardi 14 juillet 2020, 21:20
Thanks anyway, EnigmaG.
There is a display tab, but the various pre-made panels under it seem only able to be turned on or off, not modified.
samedi 25 juillet 2020, 14:23
Can you send me a picture like that from the pump side, you made me curious.
mstern
samedi 25 juillet 2020, 16:00
As you can see, the interface for the pump display is different than the interface for the vision display.
Here.
Ce message a été modifié 4 fois. Dernière modification effectuée par "mstern" (25 juillet 2020, 16:06)
