• 06.10.2026, 16:48
johnnybra
New new farbwerk 360??
lundi 20 juillet 2020, 10:53
Hi all:
I've just received my farbwerk 360 and It seems to have a new layout with 4 more corsair-like conectors
Users manual is for old farbwerk, so I don't know exactly which type of led stripe can I use.
Thank you in advance
Ce message a été modifié 1 fois. Dernière modification effectuée par "johnnybra" (20 juillet 2020, 11:02)
lundi 20 juillet 2020, 11:28
You received a brand new revision of the farbwerk 360. The additional connectors are connected parallel to the RGBpx headers and are the same type as at the mainboard.
We did this for more compatibility to other LED devices.
eisbehr
lundi 20 juillet 2020, 12:06
Never saw that change before, but that is a relly nice addition! Good work!
johnnybra
That's really great!
And what about the ws2812 generic argb LEDs? Could I try this with an adapter without danger?
eisbehr
lundi 20 juillet 2020, 12:09
All standard addressabe 5v leds should work on a Farbwerk 360, if you are within the limitations (like max led amount).
johnnybra
lundi 20 juillet 2020, 15:57
Ty.
I'll try to adapt a generic strip with a compatible conector this afternoon.
And a last question: is aquabus port still not working with aquaero?
Ce message a été modifié 1 fois. Dernière modification effectuée par "johnnybra" (20 juillet 2020, 15:58)
eisbehr
lundi 20 juillet 2020, 16:01
Afaik is the Aquabus on the farbwerk 360 currently still disabled/without any function. But who knows if this is changed too. ;)
Tasky
mardi 21 juillet 2020, 11:04
Aw dammitt......
I've only just bought the Farbwek 360 myself!!
BeachDuc
mercredi 22 juillet 2020, 08:53
Yup. This was a pleasant surprise. Thank you! Can you use both the RGBpx and normal header on the same channel?
mercredi 22 juillet 2020, 10:09
Yes, but it's not recommended and cause issues: The farbwerk 360 is monitoring the current of the LEDs due operation. If now two LEDs will be activated at the same address the current doubles and the farbwerk will monitor a abnormal current. So it is possible that it shutdowns for safety reasons.
eisbehr
mercredi 22 juillet 2020, 10:32
But that isn't new, correct? The "old" fw360 will do the same?
mercredi 22 juillet 2020, 15:40
Yes, the hardware and software is the same. The newer version only has the typical mainboard plugs in addition.
