• 11.10.2026, 12:07
Lucky75
A lot of Aqua Computer equipment - connect together.
jeudi 23 juillet 2020, 14:59
Hello Guys,
I buy a lot of Aqua Computer equipment and want to know ... more about cabling.
I have:
1. 2 Pumps - Ultimate
2. Controller 6 PRO
3. Flow Sensor
4. 4 Thermal sensors
5. 9 ports PWM splitter
6. Filter
7. Remote Control IR
8. Real Time Clock
What kind of cables and connectors I need to buy to have a complete solution ? :)
Lucky75
vendredi 24 juillet 2020, 10:40
To be more clear I will say it like that ...
Did I need to have any device to be connected by aquabus ?
Did I need all devices to be connected by USB ?
Did I need USB hub for that ?
If I use Splitty for 8 Fans what cable need to use to controller ? 4-pin PWM or 3-pin is ok ?
Bartdude
dimanche 26 juillet 2020, 11:30
On first boot everything needs to be connected by USB so the PC/Aquaero can recognise everything, after that they can be connected by Aquabus if you wish. However each time there is a firmware update you need to reconnect USB so i leave mine connected via a Hubby7. As for the fan connection it depends if the fans you have are PWM or not. :)
lundi 27 juillet 2020, 13:47
The aquastream ULTIMATE pumps can be connected via aquabus. You can use the supplied 3-pin cable that comes with the pumps. Since you have a real time clock module that features an integrated aquabus y-splitter, you can connect the pumps there.
The pumps use the same aquabus ID number by default. You have to change it for one of the pumps. This can be only done via USB with the aquasuite software in the system tab of the pump.
It is recommend that you connect both pumps via USB or at least make it possible that you can access their USB ports. If a firmware update becomes available, it can be only updated via USB. This might be a necessary step to stay compatible with the aquaero.
If a USB hub is required depends on the available USB ports of your mainboard. If there are ot enough ports available, then you need a hub or as suggested you only connect the pumps if necessary.
Splitty9 comes with a 4-pin connection cable. This allow the usage of voltage or PWM controlled fans. A 3-pin cable would only allow voltage controlled fans.
You did not mention the exact type of flow sensor. If we are talking about the classic 3-pin sensors like the High Flow sensor (without USB/aquabus), then you need this cable to connect it to the aquaero:
https://shop.aquacomputer.de/product_inf…622&language=en
If it is a USB/aquabus enabled version, then you need a y-cable for the aquabus in addition:
https://shop.aquacomputer.de/product_inf…847&language=en
You could use the supplied 3-pin cable for the aquabus but this will only work if USB is connected too because otherwise the sensor will get no power. A 4-pin aquabus cable would solve this problem and allows you to remove the USB cable. Again you should be aware that a firmware update is only possible via USB.
https://shop.aquacomputer.de/product_inf…846&language=en
Discussions similaires
