• 11.10.2026, 17:12
Asryan
Aquasuite questions : , alarms, fan hysteresis?
vendredi 28 août 2020, 18:29
I just got a Quadro today and I've installed aquasuite to control my fans and AIO
I have an arctic liquid freezer Aio and all seems good but :
  • how to set up some alarms if needed?
  • how to set up fan hysteresis ? :) it's kinda annoying to have the fan speed changing all the time... I
    Edit : for hysteresis is it the right way to do it? I set up a virtuel software sensor with aveeage @ 5 sec
Thanks !
Asryan a envoyé l’image suivante :
Ce message a été modifié 9 fois. Dernière modification effectuée par "Asryan" (28 août 2020, 23:09)
k2viper
samedi 29 août 2020, 00:03
You're on the right way.
But first of all, you selected bad source for fan control, CPU temp can have spikes and is bad as a data source for fans/pumps/etc.
You'd better rely on water temperature.
At least, to have CPU temp output more plain, use both Average(t) with more then 5 secs and Low pass filter.
Asryan
lundi 31 août 2020, 12:54
I don't have the water temps with my Arctic Liquid freezer, i can"t use it.
How does low pass filter work?
Ce message a été modifié 2 fois. Dernière modification effectuée par "Asryan" (31 août 2020, 12:57)
lundi 31 août 2020, 13:48
You can build the alarm path you need in the notification area of the Playground.
For examples just add a sensor value as input and compare it to a fixed value (the alarm level). Then connect it to the notification.
Asryan
lundi 31 août 2020, 14:32
I'm trying to set one up but can't find how, do you have an example please? thanks
k2viper
lundi 31 août 2020, 16:17
Well, there is a description inside this Playground element, it is seen on your screenshot.
"Smoothes values within the time interval"
Asryan
lundi 31 août 2020, 19:19
What values should I use ? what is damping?
lundi 31 août 2020, 20:02
what is damping?
when the value is higher, changes from the input are higher damped
Asryan
mardi 1 septembre 2020, 16:52
Ok sorry it's a bit obscure for me, if someone can tell me what would be "good" values.
Also are all those services needed to run? thanks
k2viper
mardi 1 septembre 2020, 18:44
Also are all those services needed to run? thanks[attach]7714[/attach]
"Good values" is to select another source from CPU core temp to control your fans. Use water temp.
Though, you increase Time interval and Damping inside Low pass filter, and output will be more filtered.
mardi 1 septembre 2020, 19:55
try it out
Asryan
mercredi 2 septembre 2020, 07:06
try it out
As i Said I can't select water value, it's non existent in my AIO..
damping low by deffect is 25 what would be better to put?
k2viper
mercredi 2 septembre 2020, 09:02
Better increase time interval.
Even if you cant use water temp, there is a plenty other system temps that are not so spiky as CPU core temps.
Motherboard VRM for example, is also a good source reflecting system load. Stop thinking CPU core is your only source.
Asryan
mercredi 2 septembre 2020, 13:17
Oh ok well i left it at 5sec for average and time interval
damping at 25
System stays quite silent and cool,
Fans and pumps are @ 35% speed untill 50c, them ramps up to 100@ 65c
Idle temps : 36c
gaming temps : between 50 and 60
Ce message a été modifié 1 fois. Dernière modification effectuée par "Asryan" (2 septembre 2020, 13:19)
mercredi 2 septembre 2020, 13:48
It may not be as reactive as submersion, but you could tape a temp sensor to the tubing.
k2viper
mercredi 2 septembre 2020, 19:26
Or to the radiator core.
Asryan
jeudi 3 septembre 2020, 08:07
I am not sure that is possible on an AIO... I don't have a custom WC but an Arctic Liquid Freezer 2.
All seems good anyways, temps are fine and the rig is silent, it's all I ask :)
Asryan
lundi 9 novembre 2020, 12:37
Is 25 ok for damping or should i tweak it?
k2viper
mardi 10 novembre 2020, 08:02
It is way faster if you try for yourself which value suit you most.
Discussions similaires
