• 13.11.2026, 07:24
Asryan
SAVE profiles and overview page
dimanche 1 novembre 2020, 09:56
I plan to do a fresh install of Windows soon, i wanted to know what do I need to save exactly and how to do it to keep my profiles and overview pages, sensors... etc..
Thanks for the help !
Dops
dimanche 1 novembre 2020, 10:20
Take screenshots of all settings that you consider important! I know from experience that profiles and backups are often not compatible. But that should work for the page pages. I just can't tell you exactly where the files are stored. In detail, you then have to wait again until someone can explain this to you who is more familiar with the subject.
mditsch
RE: SAVE profiles and overview page
dimanche 1 novembre 2020, 11:49
you should make sure, that you're on the latest Aquasuite-version which is possible with your licence and then copy the folder C:\ProgramData\aquasuite-data to a save place. C:\ProgramData\ is normaly hidden, you have to make ist visible before.
When windows is then freshly installed, install Aquasuite and copy the then before saved folder over the fresh C:\ProgramData\aquasuite-data. Overwrite everything.
That's it..
Asryan
dimanche 1 novembre 2020, 13:51
It will restore absolutely everything?
