• 20.11.2026, 15:10
kensaundm31
RGB Question re: OCTO and Farbwerk 360
lundi 23 novembre 2020, 11:24
Hello.
I have 10 NON RGB fans and 7 ARGB fans.(EK DRGB X3M) Also I have monoblock (ARGB), res (ARGB), pump (ARGB), distro plate (ARGB), gpu (ARGB)
I intend to get the OCTO for the pwm for all fans with no more than 4 on a channel.
As for the ARGB I guess I'd need a Farbwerk 360? I would prefer to be able to control the fans as 1 device on the OCTO and the other 5 devices separately using the Farbwerk although I could use a splitter to combine 2 of the 5 devices so they could fit into 4 channels? Will that work, does the fabriwerk connect to the OCTO or would the farbwerk connect to usb? I think i may need some adapters.
Can someone help me understand what I need?
SaiBork
lundi 23 novembre 2020, 11:30
Ha, timing, I posted almost the same thing 20 minutes before you :D Slightly different setup, so lets see what response we get.
k2viper
lundi 23 novembre 2020, 14:33
OCTO has its own 2-channel RGB controller that can drive D-RGB vardars with res and other stuff you mentioned.
You will need: rgbpx cables, number and length to suit your needs: https://shop.aquacomputer.de/advanced_se…s=rgbpx&x=0&y=0
rgbpx to D-RGB connectors, one per daisychain https://shop.aquacomputer.de/product_inf…roducts_id=3829
General limits are 90 leds per channel (180 total for octo), and 20 (?) LED controllers in software, meaning 20 different RGB effects assigned to 20 different LED groups.
20 is farbwerk360 limit having four channels, I'm not sure OCTO has the same 20 limit or it is reduced.
kensaundm31
lundi 23 novembre 2020, 20:36
NIce one thanks.
