• 10.10.2026, 06:30
Mikesa1721
Aquaero 6 with EKWB drgb fans
mardi 5 janvier 2021, 13:21
Hey all;
So I'm building my son's gaming rig and decided to purchase an Aquaero 6 to control the cooling system. I have 7 EKWB drgb fans installed in total. I have installed a RGBpx Splitty 4 on each of the 2 radiators which has 3 fans installed to keep wiring neat. Will I be able to install the 3 pin drgb cable to the 3 pin "Asus" output and have this work correctly? I plan to run each of the 3 Splitty 4's back to the aquaero 6 using an aquabus expansion board. I also have my case rgb lighting which is 4 pin. I do have a farbwek usb module, but not sure if it would work for the rgb lighting on my case. Thanks for all your help!!
k2viper
mardi 5 janvier 2021, 18:53
Aquaero does not have D-RGB controller onboard. You need farbwerk360 or octo or quadro.
Hufeisen
mardi 5 janvier 2021, 21:24
The Farbwerk is only for analog 12V LEDs.
If you want to control digital LEDs, you need a Farbwerk 360
Ce message a été modifié 1 fois. Dernière modification effectuée par "Hufeisen" (5 janvier 2021, 21:25)
Mikesa1721
mardi 5 janvier 2021, 23:01
Ok, so I'll use the Splitty 4 for the 3 fans on each radiator and then a farbwerk 360 for the drgb's on those same radiators, and then aquabus everything together or would using the usb into a Hubby 7 be better?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Mikesa1721" (5 janvier 2021, 23:18)
k2viper
mercredi 6 janvier 2021, 12:31
Yes you can use splitty4 for grouping D-RGB fans together, but make sure your fans have appropriate D-RGB connectors for splitty4. EK fans should have "motherboard type" 3-pin DRGB connectors that can be chained together and connected to current farbwerk360 version that already has motherboard type DRGB ports onboard.
BTW farbwerk360's aquabus port is not operating. USB connection is needed to control DRGB. But its not a problem.
Mikesa1721
mercredi 6 janvier 2021, 13:12
Thank You for the heads up! Thankfully I have a Hubby 7 so I'll be ok,,
