• 11.10.2026, 01:26
softlion
aquaero 6 PWM 2x 2 pin plugs: where to find ?
mardi 2 février 2021, 20:49
Hello,
i own an aquaero 6 and would like to use the 2 outputs named "PWM1" and "PWM2" in the doc.
Doc:
> 4.4. Connector “PWM 1/2”
Pulse width modulated 12 V outputs, maximum current load 1 A, carrier frequency 15 kHz. Suitable for example for 12 V LEDs, not compatible with
PWM fans or pumps.
Pin assignment: Pin 1: VCC
Pin 2: GND
Is there a firmware update that can change that output so it becomes compatible with PWM pumps and fans instead ?
All my fan/pump outputs are used :(
Also, where to find the matching plug ? What is its name ?
Ty !
RE: aquaero 6 PWM 2x 2 pin plugs: where to find ?
mardi 2 février 2021, 23:37
No.
You can use a second aquaero as a slave device or standalone or you can add a poweradjust (only one DC output, no PWM) or a QUADRO (four PWM fan outputs) or an OCTO (eight PWM fan outputs)
Here: Plug for power output connector (aquaero 5 and 6)
softlion
mercredi 3 février 2021, 11:02
With a quadro connected to aquabus i can control all the fans independently using aquasuite ?
k2viper
mercredi 3 février 2021, 12:27
https://aliexpress.ru/item/5PCS-LOT-YT49…4363.1576863165
Also these 2-pin connectors for aquaero Power output
Hufeisen
mercredi 3 février 2021, 19:38
Yes.
You need to make a Firmware Update on the Quadro first, which requires USB Connection. Once that is done, you can unplug the USB and control the Quadro with the Aquabus.
RGBpx Functions will be unavailable when using Aquabus connection only.
Ce message a été modifié 4 fois. Dernière modification effectuée par "Hufeisen" (3 février 2021, 19:43)
softlion
mercredi 3 février 2021, 20:31
If i plug that into USB only, will the aquasite software be able to control the matching fan ?
I know the aquaero will not be able to control them. But the rgb are great even if non standard and the adapter is out of price 16€ !!! https://www.amazon.fr/Aqua-Computer-Adapter-rgbpx-komponenten-anschlu/dp/B0842CLQVC
mercredi 3 février 2021, 22:05
Yes, with USB the quadro will have a tab in the aquasuite, and each of the four fan ports will have its own controller.
As to the RGB adapter, you are dealing with thieves, it lists for 2.90 EUR on the aquacomputer shop.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (3 février 2021, 22:07)
softlion
mercredi 3 février 2021, 23:40
Cool ty !
Discussions similaires
