• 02.10.2026, 07:42
FarEast
Water Block tops
samedi 15 janvier 2005, 03:32
I need to know what the plastic used on A/C waterblocks is and what temps it is rated to prefereably the minus temps they are rated to. The waterblock in question is the Cuplex Evo. I need to know if the plastic can indure temps around -100C.
Re: Water Block tops
samedi 15 janvier 2005, 04:24
The plastic which is used is "Plexiglas GS". You can get a PDF with technical details here.
It seems that -40°C ist the maximum.
FarEast
samedi 15 janvier 2005, 10:17
ok thats no problem thats well within the specs I require thanks for the response
