• 22.11.2026, 22:08
tirrorex
Issue with fan control on aquasuite x38
mercredi 3 mars 2021, 05:16
Hello,
i updated from a very old version of aquasuite in order to plug-in my d5 next.
The issue i have is with anything other than preset for the fan control.
Basically it says controller output 0% and fan output 0% but my fans are running at 2200rpm (i can see the rotation speed on the top graph)
In the fan setup below i think things are properly configured ?
Here is an image of the configuration for the aquastream ultimate
https://imgur.com/a/tVgUizD
What am i missing?
It seems to be working properly on the D5 next with the same settings
https://imgur.com/a/RCvWFal
ps: it fixed itself when i switched to the software sensor, no idea why.
Thanks
Ce message a été modifié 1 fois. Dernière modification effectuée par "tirrorex" (3 mars 2021, 06:59)
mercredi 3 mars 2021, 07:21
0% out == 100% PWM, set the output to 5% and activate hold minimum power.
tirrorex
mercredi 3 mars 2021, 21:01
That's weird, would've thought the fans would just stop spinning.
Thanks for the clarification
Discussions similaires
