• 02.10.2026, 16:57
xhamster
No display on aquaero 5 pro
vendredi 12 mars 2021, 04:38
Hi, I got a aquaero 5 pro on hand recently, I use usb connector and molex all hooked on.
PC can recognize aquaero 5 pro, but there is no display at all on the screen.
I tried unscrew all standoffs and screws, directly push the display connector.
As picture shows there should no problem with connection. Can Support or anyone give some suggestion about this issue?
Some times when I re plug it it will light for 1 sec and goes all black.
xhamster a envoyé le fichier suivant :
  • DSC_0677 1.jpg (632,23 kB - téléchargé 178 fois - Dernier téléchargement : 21 septembre 2026, 15:25)
vendredi 12 mars 2021, 09:30
Normally the display always works. How old the device?
Possibly the display is faulty.
xhamster
vendredi 12 mars 2021, 10:02
I got it from another person, So it's been used awhile. The data according to aquasuite says it's about 2 years.
Is there a way to fix it? Or it's not worth the trouble. If I want to replace it, Can I use the XT version screen?
vendredi 12 mars 2021, 10:35
no, the mounting is different.
You can try it with an replacement display. Otherwise use the devcie without the display.
Discussions similaires
