• 14.11.2026, 15:52
Gibo
Pump adapter for D5 pump #41094
vendredi 2 avril 2021, 20:53
One question...if using this adapter without an without an aqualis base series reservoir, can I use the TOP G 1/4 connectors for IN and OUT ?
Eventually even IN on the TOP and OUT on the side or viceversa ?
Or I should use only the side ones ?
Thanks !
samedi 3 avril 2021, 08:32
Quote from the product description :
When used without an aqualis base series reservoir,
G1/4 threads for fittings can be used on the top and side of the pump
adapter. Unused threads can be sealed with two G1/4 sealing screws
supplied with the pump adapter.
Gibo
samedi 3 avril 2021, 18:00
Hello,
Thank you.
I asked because the instructions on the manual PDF are a little different:
Instructions PDF
I understand from your post that I can use any combination of connectors that best suit my need.
Thanks.
Regards
