• 19.11.2026, 15:15
NGL_BrSH
How to add Dimm Temperature to aquasuite
lundi 26 avril 2021, 04:05
I have a quadro and aquasuite. I'm running a 5900x on a MSI X570 Unify.
I really enjoy the aquasuite software and I am planning on outputting that to a small LCD panel. I can get everything on there that I'm looking for except for DIMM temp. Both AIDA64 and HWiNFO64 sensors report DIMM Temps. In Select data Source The Nuvoton NCT6797D where I've found the rest of my sensors doesn't list dimm temp. Also the Generic Memory section doesn't provide temps.
Anyway to import the data?
Thanks in advance!
lundi 26 avril 2021, 04:22
if you can see similar to this --> dimm.jpg in the aquasuite 'Data quick view' tab, aquasuite is seeing the temps.
I am not familiar with the Nuvoton import procedure, but if it pulls data from the quadro, you may need to import the temps to a Soft.Sensor in the quadro.
NGL_BrSH
lundi 26 avril 2021, 04:58
Thank you for the reply. I definitely don't have that in the quick view. How did you pull in HWiNFO64? i feel like if I could import HWiNFO info, that I could grab Dimm.
Thanks!
lundi 26 avril 2021, 11:58
  • right click on the HWiNFO icon in the taskbar area
  • click on settings
  • activate the 'Shared Memory Support' option (shared_mem.jpg)
