• 22.11.2026, 21:28
cptninc
Which port is input for the RGB on the 3090 blocks?
mercredi 28 avril 2021, 20:51
I checked the manual and it says to just try both and see what happens. I'd rather not waste my time playing a guessing game.
mercredi 28 avril 2021, 22:01
Assuming (a), the connector is visible, and (b), the rgbpx strips are similar to those available on the web shop, you should be able to see IN and OUT markings partially tucked under the connectors... not the markings on the back of the strip. rgbpx_in.jpg
cptninc
jeudi 29 avril 2021, 16:51
Unfortunately, any labels on the connectors are hidden by the block.
I guess it's all moot anyway because the connectors are on the bottom of the block and thus there isn't actually space available to have anything plugged in. I've tried with two motherboards (Asus Rampage VI Extreme and Gigabyte Aorus Xtreme TRX40) and the blocks hit the motherboard without anything plugged in to the RGB ports.
