• 22.11.2026, 22:30
Dundys
No USB 2 Header on Motherboard
mercredi 5 mai 2021, 20:11
Hey Guys!
Currently I have Asus x99 E-WS 10G workstation with plenty of onboard USB 2 headers. I'm thinking on getting Asus x299 SAGE10G workstation, but unfortunately that motherboard doesn't have any onboard USB 2 headers. Any idea how I would be able to connect Aquaeros USB 2 cable, whats the work around it.
Thanks
mercredi 5 mai 2021, 22:41
One opion would be to use this USB CABLE and connect the 'A' style connector to an external port on the back panel, snake it inside and connect to a HUBBY7... boom, seven USB 2.0 ports.
EDIT: OK, that won't work... looks like no external USB 2.0 ports either. That leaves a cable like THIS to the internal USB 3.0 port marked [14]. usb3.jpg
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (5 mai 2021, 23:25)
Dundys
jeudi 6 mai 2021, 09:08
Thanks my friend for trying to help. Looking at the availability and choices I think I will pass on this GEN especially on motherboards without any onboard USB2, they are needed, why on earth Asus would take them off from workstation boards. I think I will stick with my current system until next year I don't want to rush and regret.
Thank you InfoSeeker :thumbup:
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (6 mai 2021, 09:09)
mandrix
vendredi 7 mai 2021, 23:10
Well do you have Pcie? I did not look up your board,but you can get cards for USB, SATA, etc. For example I run a Pcie 8 slot SATA card on my ASUS Prime... HTH
