• 19.11.2026, 22:38
ae111James
Aquasuite profiles not starting after MSI Afterbuner installation
vendredi 21 mai 2021, 06:08
Hello guys,
Before installing MSI Afterburner, aquasuite was working great for months.
Anyhow, I've installed afterburner recently and from there on, whenever i boot my PC, aquasuite profiles doesn't work anymore.
I've tried manually changing the profile from automatic to any other profile, no change.
Upon researching, i've seen a post that mentioned aquasuite should be exempted in RivaTuner (RTSS).followed the instruction and now, it seems like 50/50 chance whenever I start my PC.
either aquasuite profile is working or it isn't upon boot.
**Aside from the exemption in RTSS, I've also already deactivate MSI Afterburner upon boot.
PC is running in Win10 64bit, last update was weeks ago and aquasuite (up to date) was still working normally.
need help what to do for the aquasuite profiles to load normally again ?(
vendredi 21 mai 2021, 07:48
This is an issue with the crappy rtss.
This software works like a virus. You must define "aquasuite", "Aqua Computer Service Helper" and "Aqua Computer Service" as an exception in RTSS.
ae111James
vendredi 21 mai 2021, 07:57
Guten Morgen Sebastian,
Thanks for the quick response! :thumbsup:
I thought aquasuite.exe was already enough for the exception. Will do this immediately
Ce message a été modifié 1 fois. Dernière modification effectuée par "ae111James" (21 mai 2021, 07:58)
ae111James
vendredi 21 mai 2021, 16:12
Hallo Sebastian,
I did what you said and it seems that now, the automatic profile loads properly.
Unfortunately, a new problem for me occurred.
1 of my temp sensors wasn't detected upon boot.
I restarted the aquasuite service and it loaded properly afterwards.
Like I said before, aquasuite worked great before I installed MSI Afterburner & RTSS
Do you know if uninstalling RTSS can solve everything or does this leave traces after uninstalling?
