• 29.11.2026, 09:29
FarEast
Connecting the Eheim 1048 to a aquastream Control
samedi 15 janvier 2005, 03:50
Connecting the Eheim 1048 to a aquastream Control plate.....is this possible? ???
Re: Connecting the Eheim 1048 to a aquastream Cont
samedi 15 janvier 2005, 04:07
Short and easy: NO! ;D
And plese don't think that the 1046 and aquastream are the same pumps.
The engine inside the aquastream ist totally different and that's also the reason why you need the controller to use it.
FarEast
samedi 15 janvier 2005, 10:15
ok no problem ...... i already have an aquastream its just the flow sensor is actually killing my flow and raising water temps! >:( I guess i will remove the 1048, flow sensor and put the Aquastream back in place.
x-stars
dimanche 16 janvier 2005, 18:32
Do you own an Aquaero? Then you could overclock the Aquastream easily to get more power.
Another opportunity would be to modify the flow sensor:
You could drill the input to get a bigger "hole". Then change input and output, so you do not need to check the right "impulse/L", the output is 5,6mm big, according to digmesa you will need 196 impulse/L now (sorry, I can't explain it better ::)).
cya
x-stars
