• 10.11.2026, 10:59
emperorjj1
RBGpx help
lundi 31 mai 2021, 07:29
Hey guys ive purchased the items below and have run into a connectivity issue. both the adapter and OCTO are female connectors. Im wondering if something like the RGBpx cable, length 4 cm Product no.: 53259 is the missing piece i would need to get the LED strip to work with the OCTO?
Aquacomputer RGBpx Adapter For Components With Motherboard Header (53282)
Aquacomputer RGB LED Strip - 25cm - Black (53185)
Aquacomputer Connector for RGB-LED-Strips | White 70 cm (53148)
Remayz
lundi 31 mai 2021, 17:43
that works, or the longer version that ships with farbwerk360 :
https://shop.aquacomputer.de/product_inf…roducts_id=3764
that's what i use with the same adaptor you have to connect to standard ARGB fans.
Discussions similaires
