• 19.11.2026, 02:52
xhamster
Aquaero solder rookie misktake
mercredi 2 juin 2021, 10:28
I think I over heat the board and the ring comes off, Is there any way to fix it? Any tips will be appreciate.
Thanks. Pics attached
xhamster a envoyé le fichier suivant :
  • DSC_2044 1.jpg (444,07 kB - téléchargé 260 fois - Dernier téléchargement : 16 novembre 2026, 15:17)
mercredi 2 juin 2021, 10:36
The 2 Pads in the middle are ground. This 2 pare are connected in the bottom pcb layer. I think you pcb is working, you have only connect the 2 Pins on the bottom layer.
xhamster
mercredi 2 juin 2021, 12:06
Unfortunately the back ring is off too. I tried to solder it directly on the board but it won’t boot the fans.
What is the ring called? I’m think buying some online to replace them order to see if it will help
Back pic attached.
mercredi 2 juin 2021, 13:06
this is the 12V supply, the pad is directly connected to a inner layer.
you can try to connect the 12V supply to the + connector from the capacitor next to power connector.
xhamster
jeudi 3 juin 2021, 07:59
Is this you're talking about?
  • DSC_2047.jpg (617,81 kB - téléchargé 231 fois - Dernier téléchargement : 16 novembre 2026, 00:06)
jeudi 3 juin 2021, 20:42
no, this is the Ground Terminal.
Discussions similaires
