• 14.11.2026, 02:49
sidilarsen
Flow Next + aquasuit
samedi 10 juillet 2021, 16:04
Dear All :)
I have 2-3 questions
So i'm interested by the flow next sensor
The RGB controler is it an ARGB ? can i connect Standard ARGB strip on It ?
With aquasuit, Can i Control my Motherboard fan header ?
If not Can add the value in Speed Fan program ?
Best regards
Steve
Hufeisen
lundi 12 juillet 2021, 17:35
The RGB Controller is compatible with WS2812B LEDs. Most ARGB Strips use this LEDs.
You may need an Adapter for your LED strip. https://shop.aquacomputer.de/product_inf…roducts_id=3829
No, the Aquasuite can only control Devices from Aquacomputer.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Hufeisen" (12 juillet 2021, 17:37)
sidilarsen
mercredi 14 juillet 2021, 10:30
Thank you very much
Another question
With the flow next
can i monitor temp on HWinfo if yes, can i monitor it without installing aquasuite
Best regards
Burnout_Student
mercredi 14 juillet 2021, 16:57
Hey,
yes it works for me showing temperature, flow, water quality and conductivity in hwinfo withour aquasuite installed.
You just have to connect it via the usb to the motherboard.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Burnout_Student" (14 juillet 2021, 16:58)
Jacob
mercredi 14 juillet 2021, 17:11
If you want to use aquasuite to monitor or set light strips
Many devices support RGBpx connector
After connecting the device to the PC using a USB 2.0 socket
You can use aquauite to set the lighting effect
Or install farbwerk 360, an all-around peripheral
Enjoy complete lighting control
sidilarsen
mercredi 14 juillet 2021, 19:45
Nice . Thanks you all
