• 31.10.2026, 12:59
etoel
High Flow NEXT - Aquaero, no settings for this flowmeter
mardi 13 juillet 2021, 17:15
I tried to use the signal - fan header cable and connect the flow meter to the flow connector on Aquaero (just as the old High Flow) - the reading is off the charts and I don't find any comparable model to pick under flow meters in Aquasuite X.40.
I just want the flow from NEXT to appear on the Aquaero display. This should be possible?
I also have the HighFlow NEXT connected via AquaBus (through an X4 hub) if that makes a difference.
Jacob
mercredi 14 juillet 2021, 17:18
Do not use the signal port of the flowmeter to connect to aquaero
Just connect the USB and aquabus cable
You can set it in the aquaero option of aquasuite
Let the value of the flowmeter appear in the aquaeto screen
Before that, you must let aquabus scan your flowmeter
Aquaero will allocate an address to the flowmeter. :)
etoel
mercredi 14 juillet 2021, 22:47
I tried this now, just connecting the aquabus cable and USB.
The HighFlow next lets me assign an address from 58-61
When I try to scan for devices under aquaero/aquabus it only finds the aquabus hub with address 112.
No flowmeter other than flow 1/2 is available under aquaero/sensors/flowmeter
No new flowmeters appear under aquaero/information pages/flow sensors
Aquaero 5 pro firmware 2104
Highflow NEXT firmware 1010
Other aquabus devices connected:
- farbwerk 20
- D5 NEXT 30
Ce message a été modifié 1 fois. Dernière modification effectuée par "etoel" (14 juillet 2021, 23:05)
etoel
jeudi 15 juillet 2021, 10:11
All good now - main problem was sitting 30 cm in front of the monitor...
