• 07.10.2026, 18:27
Ryan_F_Mercer
Can Aquasuite Shutdown Windows 10 When Temperature too High?
dimanche 18 juillet 2021, 08:41
I have a Quadro installed on my computer with two temp sensor inputs: one from my CPU and one from my coolant Pump. I have the aquasuite software installed and can monitor my temps nicely. I've been able to setup a warning notification for high temperature, but I can't figure out how to send a shutdown command to Windows 10. Is this possible and if so how?
dimanche 18 juillet 2021, 13:00
You can create a virtual software sensor via the playground and then pass this value to a notification.
The notification can be anything from a desktop popup to email to Windows shutdown.
Ryan_F_Mercer
dimanche 18 juillet 2021, 21:14
Okay. I've seen others say it isn't possible for the Quadro, so thank you for this information. I'll give it a try.
DAsunder
mercredi 25 août 2021, 03:22
Could you let me know if this worked with your setup?
I'm trying to figure this out since AC didn't respond yet, I have a relay alarm that isn't working properly. All the other solutions either with Aquasuite or motherboard 3 pin cable signal alarms didn't work. Could you also let us know which platform you're using? I've tried all of this on amd x570 and the bios didn't shut down the system even when Aquasuite cut off the signal to the mobo.
Ryan_F_Mercer
Help! Having Issues with this Forum
dimanche 5 mars 2023, 21:31
I'm adding this to a really old post because I am unable to login to the main English forum page and am unable to create new threads. I am logged in though and can add posts to old threads. But when I go to the english forum page it says I'm not logged in and when I try to it says I don't have access to that page. I'm a paying customer and would like to be able to ask questions about the product in the forum, but I can't seem to figure out how to contact forum support. Any help would be appreciated.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Ryan_F_Mercer" (5 mars 2023, 21:33)
RE: Help! Having Issues with this Forum
dimanche 5 mars 2023, 22:33
Most likely you have your browser set to not allow cookies, which is how this forum software keeps track of your being logged in.
