• 29.09.2026, 08:43
Flop Ysh
D5 NEXT: Fan header not functionnal
mercredi 21 juillet 2021, 16:59
Hello!
it's me again ^^
that time I can't get the fan header of the d5 next working
changed cables, used only one fan... nothing. Did a factory reset too on the D5, didn't change anything
I first used the Splitty but when I plug the Splitty directly to the Mb that works as intended and with 4 fans on it.
What am I missing?
Hufeisen
mercredi 21 juillet 2021, 17:53
You have to configure the Fan Port in the Aquasuite Software..
You can select if you use it as FAN port or as FLOW port.
If Flow Port is selected, the Fans do not work.
Flop Ysh
mercredi 21 juillet 2021, 17:58
Thank you very much for your answer
I went through all the pages in D5 Next and Aquasuite sections, and I didn't find anything close to that ?( Could you guide me to where I can change that?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Flop Ysh" (21 juillet 2021, 18:00)
Flop Ysh
mercredi 21 juillet 2021, 18:12
From the manual, it seems that the header is configured by default as a fan output. And if there is no virtual sensor using the header, the Fan panel under D5 NEXT is all I should need to set speeds and read the rpms...
I actually don't see what to do, since I did a factory reset and I don't have any virtual sensors
Ce message a été modifié 1 fois. Dernière modification effectuée par "Flop Ysh" (21 juillet 2021, 18:13)
Flop Ysh
jeudi 29 juillet 2021, 20:12
tried again with the last Aquasuite software. Nothing changed. No surprise since the firmware hasn't been updated
I'm contacting the support
