• 16.11.2026, 07:35
Ryan_F_Mercer
Aquasuite Won't Auto Start with Windows 10
mercredi 21 juillet 2021, 23:22
I have the Quadro with Aquasuite, but it doesn't load with Windows. When I start it manually, it shows up in the systray as normal, but I can't get it to auto start when the computer loads. I've tried turning on auto start in the Aquasuite settings. I've tried running it as administrator. I've tried running it in Windows 8 compatibility mode. I've tried placing it in the user Startup folder. I've tried placing it in the system Startup folder. I've tried loading it in Task Scheduler. The only thing that shows up in the systray is the profiles selector, but not the Aquasuite icon. What am I doing wrong?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Ryan_F_Mercer" (22 juillet 2021, 06:56)
Grestorn
jeudi 22 juillet 2021, 11:04
Using the autostart feature of Aquasuite should generate this entry called "aquasuite autostart" in Windows' Task Scheduler:
Do you see that entry? Is it marked as "Running" after you've logged on?
Ryan_F_Mercer
vendredi 23 juillet 2021, 07:22
Found it! It was "ready" but not "running." I needed to select "Run with highest privileges" and change the configuration from Windows 8 to Windows 10. That fixed it. Thank you for the help! :thumbup:
