• 07.10.2026, 14:27
turgin
D5 NEXT RGBpx output not working
mardi 27 juillet 2021, 03:56
I have a D5 NEXT that I've had connected via Aquabus for quite some time now. I'm reworking my loop and ditching the Aquaero and farbwerk 360 in favor of an Octo so I want to use the RGBpx output now. I have changed the D5 from Aquabus to RGBpx LED in the system tab and checked everything I can think of on the RGBpx tab as well. Lighting slider is on and there is a controller assigned but still no output at all. The pump LED ring works fine. I have tried a different cable, different strips and checked for bent pins all to no avail. I even tried a new install of Aquasuite and reset the pump to factory defaults.
Any other ideas or suggestions to get the RGBpx output to work?
Flop Ysh
jeudi 29 juillet 2021, 19:57
Hi!
is that the same issue as [solved] D5 NEXT: RGBpx output not functionnal ?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Flop Ysh" (29 juillet 2021, 19:58)
turgin
jeudi 29 juillet 2021, 21:22
Hi!
I checked that setting first and also checked it via the pump display itself.
