• 22.11.2026, 18:24
Jesaul
Aquasuite constantly crashes after sleep/wakeup
samedi 31 juillet 2021, 21:25
For quite some time aquasuite has started to crash constantly after sleep/wakeup. The current version runs at X.42 on latest Windows 10.
Here are the events:
PowerEvent handled successfully by the service.
Application: AquaComputerService.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at LibreHardwareMonitor.Interop.AtiAdlxx.ADL_Main_Control_Create(ADL_Main_Memory_AllocDelegate, Int32)
at LibreHardwareMonitor.Interop.AtiAdlxx.ADL_Main_Control_Create(Int32)
at LibreHardwareMonitor.Hardware.Gpu.AmdGpuGroup..ctor(LibreHardwareMonitor.Hardware.ISettings)
at LibreHardwareMonitor.Hardware.Computer.AddGroups()
at LibreHardwareMonitor.Hardware.Computer.Open()
at GSjf6OTwismlhMBRfJQ.nnefDaTUFY07v6JTVcr.sx2YgOo6QOTvpvJ6KWk(System.Object)
at GSjf6OTwismlhMBRfJQ.nnefDaTUFY07v6JTVcr.vQHeWVJwiF(System.Object, System.ComponentModel.DoWorkEventArgs)
at System.ComponentModel.BackgroundWorker.OnDoWork(System.ComponentModel.DoWorkEventArgs)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(System.Object)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr, System.Object[], System.Object, System.Object[] ByRef)
at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(System.Runtime.Remoting.Messaging.IMessage, System.Runtime.Remoting.Messaging.IMessageSink)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
Faulting application name: AquaComputerService.exe, version: 10.2.7879.27248, time stamp: 0x610156c1
Faulting module name: atiadlxx.dll, version: 27.20.22021.1002, time stamp: 0x60f9835b
Exception code: 0xc0000005
Fault offset: 0x000000000000441d
Faulting process id: 0xd54
Faulting application start time: 0x01d7858807e4e761
Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe
Faulting module path: C:\Windows\SYSTEM32\atiadlxx.dll
Report Id: a5c266c8-7b50-4e21-a2ca-d1c2e0471ca3
Faulting package full name:
Faulting package-relative application ID:
WinstonWoof
dimanche 1 août 2021, 07:02
I havent checked my logs but this feels related to my issue where sebastian advised it should take approx 20 seconds for the Aquacomputer service to restart after wake (but in my case doesn't)
Aquasuite service does not restart on Wake from Sleep
dimanche 1 août 2021, 09:15
Deactivate the GPU Monitoring, this error message looks like an Driver issuse with with hardware monitoring.
Jesaul
dimanche 1 août 2021, 11:36
I don't monitor GPU in sensors at this moment. But I've changed a videocard 2 month ago.
I've found the old videocard settings in captureddevices and have removed it from there. Let me see if issue is reproduced.
Grestorn
dimanche 1 août 2021, 14:35
Same is happening for me, and I have all hardware monitoring options disabled.
Jesaul
mercredi 4 août 2021, 19:46
Ok, looks I've had dvi cable loosing a connection and monitor disconnecting/reconnecting after wakeup.
It kills Aquasuite.
Jesaul
mercredi 4 août 2021, 20:27
Ok, it crashes again.
Null pointer de-reference is not an excuse that there is driver problem :)
Exception Info: System.NullReferenceException
at AquaComputer.Service.ServiceMain+<mainTimer_Elapsed>d__111.omrfrC9cvJXDwLgJfn1f(System.Object)
at AquaComputer.Service.ServiceMain+<mainTimer_Elapsed>d__111.MoveNext()
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1151, time stamp: 0x891df6d3
Exception code: 0xe0434352
Fault offset: 0x0000000000034ed9
Faulting process id: 0xd10
Faulting application start time: 0x01d7890cc4f13f6a
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: adb3aec1-af0a-4362-9ca7-e68a39d4c17a
jeudi 5 août 2021, 07:38
Make a clean install with the aquasuite setup.
Discussions similaires
