• 03.10.2026, 02:01
stu_allen
Aquagrafx 6800 Rev2 fitting
mardi 18 janvier 2005, 23:42
Just starting to put my cooling system together.
As far as fixing the 6800rev2 onto the card goes, should i use thermal pads for the ram/powerfets? I cant seem to make it have a "flat" enough connection to use some artic silver ceramique.
Should i use new pads or reuse the ones from the stock cooler?
major23hh
Re: Aquagrafx 6800 Rev2 fitting
mercredi 19 janvier 2005, 01:02
I think you should use some thermal paste, because pads are to high (Attention, only an speculation ;) ).
propurple
mercredi 19 janvier 2005, 01:03
can you buy thermal pads from ac store?
Stefan_K.
mercredi 19 janvier 2005, 01:45
Hi Stuart,
just use the pads from the air cooler. On the GPU use thermal paste.
Cheers
Stefan
