• 08.10.2026, 02:18
Netherspark
Switching profiles via bat file or other command?
dimanche 15 août 2021, 15:17
Is it possible to switch Aquasuite profiles using a .bat file or other command? I'd like to set a custom desktop button via Rainmeter to swap profiles, I assume it is possible if you know the right command.
It may also be a better idea to have the command simply turn RGBpx lighting on & off.
mercredi 18 août 2021, 11:37
You can create a hotkey command via playground to switch the profiles.
Otherwise switch the profiles via Notifications in the playground.
Grestorn
mercredi 18 août 2021, 13:30
That's actually a great feature I have missed so far.
What would be very helpful would be to have two additional triggers in the Playground: System start, system shutdown and maybe system sleep and wakeup.
Would that be possible?
mercredi 18 août 2021, 13:50
System start and wakeup is the same for the service.
You can easy build a one constant value with a notification. When the service starts, the notification is fired.
Shutdown and Sleep is not possible. On this events, the service shut down.
Grestorn
mercredi 18 août 2021, 14:23
If the system signals you that the service should shut down, don't you have enough time to at least trigger a profile change? Usually a service gets enough time to do its controlled shutdown procedure.
SERVICE_ACCEPT_PRESHUTDOWN und SERVICE_CONTROL_PRESHUTDOWN sollte da doch helfen. https://docs.microsoft.com/en-us/windows…andler-function
Ce message a été modifié 1 fois. Dernière modification effectuée par "Grestorn" (18 août 2021, 14:25)
Discussions similaires
