• 30.11.2026, 22:54
Alexandro
Aquaero HWInfo and AIDA64 dissapointing pressure sensor issues
lundi 23 août 2021, 12:29
Dear aquacomputer
I have 2x flowmeters and 1x pressure sensor connected to aquaero controller, and there are very strange issues with it:
1. There are no mps pressure sensor values shown available in hwinfo (v7.06-4500). I reinstalled hwinfo - not helped. I can see the values in aquasuite, which tells that the sensor is fine. Why does flowmeter values shown and pressure sensor values are not?
2. AIDA64 shows the pressure values, flowsensors are showed as another device, but pressure sensor showed as a part of aquaero which is weird. However, there are no such parameter in logging menu. Why?
Alexandro a envoyé les images :
lundi 23 août 2021, 18:45
This is probably a HWINFO issue. Maybe you should post your findings on their forum. HWINFO does support Aquacomputer devices. Martin (author of HWINFO) just added support for Leak Shield. He is usually very good about adding missing sensors and correcting sensor names when a user points out that something is missing or called the wrong thing. Good luck!
