• 02.10.2026, 20:14
Mark74
Pressure sensor mps pressure Delta 40
mardi 24 août 2021, 06:14
Hi Guys,
Any idea when the Delta 40 sensor will be back in stock?
If not, is it possible to buy a higher range pressure sensor thats available and change some of the internals? Or is it possible to wire in an industrial grade or motorsport grade pressure sensor? Most sensors I play with use strain gauges or similar with an amplifier. I assume the mps Delta sensors work the same way?
https://shop.aquacomputer.de/product_inf…roducts_id=2902
Also are there any plans to release a NEXT version of the pressure sensors? Would seem logical considering the flow sensors are now available as a NEXT option.
mardi 24 août 2021, 12:42
It appears HighFlow.nl has some of the MPS Pressure Delta 40s in stock.
Edit: that was about 4 hours ago, they show void now.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (24 août 2021, 16:33)
Mark74
jeudi 26 août 2021, 05:29
Thanks mate, I placed an order with them, shipping to Australia was worth more than the device.
Next question, you know the whereabouts of one of these?
https://shop.aquacomputer.de/product_inf…953&language=en
Whats going on with Aquacomputer? Seems they running out of stock for everything!
Do they need to employ some support staff?
Remayz
samedi 28 août 2021, 21:09
there's like some situation with sourcing electronic chips these days ^^'
It's not specific to AC, and when they find a second source or an alternate chip, it needs to be fully qualified and tested as a replacement before production, so.. all in all... delays, low stocks and stuff.
Mark74
dimanche 29 août 2021, 05:23
Thanks, I didn't give that much thought as I haven't come across supply shortages for relatively simple hobby level parts. But then again I rarely buy that sort of stuff. My normal day job is industrial chemical process and packaging equipment.
Discussions similaires
