• 19.11.2026, 20:15
protocrash
OCTO has stopped exposing its sensors to Windows, except for Aquasuite
mercredi 27 octobre 2021, 19:16
Hi there,
Been using OCTO and Aquasuite for a few years without issue. Until recently, perhaps after an update of Aqua or firmware update, the sensor info for my water and ambient temp have stopped appearing for any other software except for Aquasuite.
In aquasuite the temperatures are read correctly. Anywhere else the sensors aren't shown at all.
I'm using aquasuite x.46 insider and its fully up to date. Firmware on the OCTO is also up to date.
I'm looking at device manager and OCTO appears OK.
I'm looking for the sensors in AIDA64, HWinfo and HWmonitor.
All advice welcome!
Thanks
Remayz
mercredi 27 octobre 2021, 19:36
ther's been changes to the firmwares, and Aida, and HWinfo need to be updated to read them again :)
It's been implemented in the latest HWinfo beta from what i heard.
Jacob
RE: OCTO has stopped exposing its sensors to Windows, except for Aquasuite
mercredi 27 octobre 2021, 20:14
Hi there,
Been using OCTO Thanks
After testing, AS only supports HWinfo up to version 6.42. Higher versions are not yet supported. Including versions 700, 702, 704, 706, 710, 712... :)
Remayz
mercredi 27 octobre 2021, 20:25
it works on the latest beta, he updated with the new aquacomputer SDK, for the new firmwares
https://www.hwinfo.com/forum/threads/hwi…-released.7653/
Jacob
mercredi 27 octobre 2021, 20:44
I installed HWinfo's latest BETA and official version 712, it cannot be displayed in X46, and the last version that can be displayed normally is version 642. :)
mercredi 27 octobre 2021, 21:10
you have to enable the shared memory support in hwinfo.
Jacob
jeudi 28 octobre 2021, 08:12
Thanks !
I’ll try! :)
[/url]aquasuite_2021-10-28_15-25-43 by Jacob Tien, 於 Flickr[/img]
Yes~
Just now I turned on the HWinfo memory sharing option,
Now I can connect to HWinfo information in X46.
Thank you very much~! :D
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jacob" (28 octobre 2021, 09:29)
protocrash
jeudi 28 octobre 2021, 10:36
Great! Thanks so much for the help. I updated HWinfo to the latest beta and indeed all works fine!
protocrash
jeudi 28 octobre 2021, 11:28
Hmm... still no joy with AIDA64 Extreme. Updated to v 6.50.5800 but the sensors still don't appear...
Is it a matter of waiting for AIDA to release an update to support the sensors?
