• 22.11.2026, 22:26
protocrash
Aqua curbe controllers have suddenly stopped working
jeudi 28 octobre 2021, 10:41
Hi there!
I've been happily using my aquasuite and OCTO for a couple of years now. Two weeks ago though I've been having an issue:
- I've setup my fans using "Curve controller" with Water temperature as the controller source.
- This worked fine up to now...
- However now when the OCTO is set on "curve controller" the fans go to 100%, as if they're not getting any signal
- The water temperature is working correctly
- When I set the fans to power preset they work correctly
- If I go from "curve controller" to "power preset" many times, sometimes the "curve controller" will work correctly
You can see a video of this in action here:
https://vimeo.com/639863514/341278d882
Thanks!
Ce message a été modifié 1 fois. Dernière modification effectuée par "protocrash" (28 octobre 2021, 11:19)
jeudi 28 octobre 2021, 11:15
In the video it looks like you are at 0% PWM at the given water temperature, which means that the fans, according to the PWM specification, go to 100% speed.
If you set the minimum power to 5% instead of 0% the problem should be solved.
protocrash
jeudi 28 octobre 2021, 11:20
I think you're right!
Thanks so much! Never would have thought about this!
For now its working - if it causes trouble again I'll report back, but I think we're good!
jeudi 28 octobre 2021, 11:21
You're welcome
Discussions similaires
