• 12.11.2026, 18:09
egothrasher
Aquasuite Settings
lundi 22 novembre 2021, 00:24
I am currently running a dual loop system with the 5800X and RTX 3080 and was wondering what some good settings for aqausuite are. At the moment I have target temp for the Pump, set at 34 C. The fan settings are on a curve at, with 20C at 0% going to 100% at 40C. Currently just browsing the web I am sitting at around 26-27C, pumps around 1900 rpm, fans around 960 rpm. All help appreciated.
lundi 22 novembre 2021, 14:19
For everyone a different setting is good, it always depends on what you want to achieve.
My tip, set the pump to a fixed value at which it does not annoy you, the flow rate is not really relevant for the cooling performance.
For the fans, the question is whether you want maximum cooling or minimum noise.
Your setting for the fans sounds very reasonable though.
