• 03.10.2026, 07:05
Remayz
vendredi 3 décembre 2021, 11:47
to add to this, 4 pin PWM fans are always powered by a constant 12V and have an embedded controller that varies the motor speed depending on the PWM input.
3 pin DC fans are controlled by varying the input voltage and have no electronics inside.
alexkyriak
vendredi 3 décembre 2021, 12:23
Thanks mate, appreciated.
Jacob
RE: Splitty 9 fans diagram (how many splitty9s?)
dimanche 5 décembre 2021, 19:22
Citation de "alexkyriak"
I have 18 140mm fans, using the six channels of XT 6 and LT 6.
Three fans in one channel, currently controlled normally
It's too complicated to go through a hub, whether it's powering or arranging cables. :)
alexkyriak
mercredi 22 décembre 2021, 13:59
OK, so it's time to install the fans and splitty9s! So I understand to make these EK fans work, I need to disable the Tach signal. I think I need to clip this pin, as highlighted in yellow, on 8 of the Splitty9 fan headers, which I understand is the Tach pin. I understand I do not clip this on the RPM header.
Based on this PWM header diagram:
Is this correct?
Much appreciated guys :)
Ce message a été modifié 1 fois. Dernière modification effectuée par "alexkyriak" (22 décembre 2021, 14:00)
alexkyriak
RE: RE: Splitty 9 fans diagram (how many splitty9s?)
mercredi 22 décembre 2021, 14:01
@jacob I assume this uses lots of splitter cables?
