• 06.10.2026, 23:35
Danjr
12v RGB Splitty4 and Farbwerk?
jeudi 16 décembre 2021, 04:23
Right it seems I've balls things up a bit.
I've purchased:
EK 120 RGB Fans (4 pin) x 12
Octo
4 x Splitty4
Farbwerk 360
2 x D5 pumps
I had intended to control the pumps, RGB and fans all through this setup.
However I've realised that neither my Splitty4 or Farbwerk 360 will work with 12v RGB. But I think the Splitty4 and Octo will work alright with PWM on the fans - is this correct?
Secondly:
Are there any suitable splitters and controllers for 12v RGB?
New to this so appreciate any help.
Thanks
Dan
Remayz
jeudi 16 décembre 2021, 12:14
are you sure the fans are 12V rgb? as far as i know, EK only made ARGB fans (5v).
for analog RGB, maybe look at the original Farbwerk https://shop.aquacomputer.de/index.php?cPath=62_2244
Danjr
mardi 21 décembre 2021, 01:59
These are the fans I have: https://www.ekwb.com/shop/ek-vardar-evo-…gb-500-2200-rpm
Unfortunately I didn't get the ARGB version.
I'll have a look at the original Farbwerk thanks.
Discussions similaires
