• 16.11.2026, 21:06
gvsykes
Converting flow sensor rpm into l/h data in aquasuite
mercredi 29 décembre 2021, 19:53
Hello all,
Just installed my new quadro and getting to grips with it.
In one of the 4-pin headers on the quadro i have connected a 3-pin connector from an alphacool flow sensor (tried to get the NEXT but out of stock and i just thought I would put it in and see what happens).
Basically what I am trying to do within aquasuite is take the rpm from the flow sensor, convert that into a L/h reading (using alphacool provided table) and then use that L/h "value" as an output to control the pump speed, which is also connected to the quadro.
Is this possible? I know it sounds like a very roundabout way of doing things but I figured I would give it a go.
Thanks for your time.
gassynizz
lundi 10 janvier 2022, 02:48
Well, are you getting a reading of rpm's to actually show up in aquasuite?
If yes, then you go to the playground and create a virtual sensor. Use the rpm as the input. Then use functions to make whatever conversions are required based on your table. Set your final result as the output. Now you can set fan speed based off the aquaservice virtual sensor.
If you're not getting rpm's from the cable recognized, then I don't know what to do.
Discussions similaires
