• 30.09.2026, 17:42
obelix
Arctic Fans compatibility
mercredi 5 janvier 2022, 00:09
Hello,
Can anyone confirm that this fan is compatible with Octo / Splitty(x) devices?
https://www.arctic.de/en/P12-PWM-PST-A-RGB-0dB/ACFAN00231A
Here is the technical sheet:
https://www.arctic.de/media/cb/67/c0/1638880679/Spec_Sheet_P12_PWM_PST_A-RGB_0dB_EN_white.pdf
where we can see that the PWM connector is a 4 pins
and that the argb connector is a 3 pins.
I guess I will need one of these adapters :
https://shop.aquacomputer.de/product_inf…roducts_id=3831
https://shop.aquacomputer.de/product_inf…roducts_id=3829
Is this correct?
Is this fan compatible with Octo / Splitty(x) devices?
Thanks in advance
Philippe
Ce message a été modifié 2 fois. Dernière modification effectuée par "obelix" (5 janvier 2022, 00:24)
mercredi 5 janvier 2022, 08:26
The fan has a PWM connection and is therefore controllable via the OCTO, since the fans offer the possibility to connect additional fans on both the PWM and aRGB connection, no splitter is necessary.
Each fan has 12 LEDs, so you can connect 7 fans to one RGBpx channel of the OCTO and at 0.11A you can also connect them to one fan channel if you want.
As adapter you need this: https://shop.aquacomputer.de/product_inf…roducts_id=3829
Translated with www.DeepL.com/Translator (free version)
obelix
mercredi 5 janvier 2022, 14:09
Awesome !
Thank you very much for your detailed answer.
dimanche 9 janvier 2022, 12:15
I bought a three-pack of the fans for testing :-)
It works as hoped, you can control the LEDs individually via the three fans connected in series, and therefore also control each fan with its own effect, or all together with a continuous effect, as with LED strips connected in series.
You need this Adapter.
obelix
dimanche 9 janvier 2022, 16:16
Yes, I also ordered some, along with the adapter. The package is on its way... :)
Thanks for the confirmation, can't wait to try it out!
dimanche 9 janvier 2022, 16:20
You're welcome.
