• 11.10.2026, 05:48
RBMDragon
Aquasuite X cross sensors not updating
dimanche 6 février 2022, 21:26
First of all; excellent software, just had to say it.
Second;
After the PC returns from Sleep state the sensor data between devices and Playground is not showing any values.
Resetting the data source doesn't help neither does the restarting the service and program.
Only rebooting the computer helps.
(On some much smaller notes; missing 'l' in "Gobal Profiles" under Playground. Should be "Global Profiles")
RobinXe
dimanche 20 février 2022, 09:13
I have a similar problem, except it is not brought on by sleep, it just develops over time. When I first restart the computer devices can see the sensor data from other devices, when I look again later this data has gone. In Playground all inputs are 'NaN'. When I reset the data source, the correct values are shown in the source browser on the right, and even display in the Leakshield 'old and new' setup pages, but they never seem to get passed to the main module for the device.
Running Aquasuite X.47, Windows 10 64-bit.
dimanche 20 février 2022, 11:16
Helpful would be the information of which devices we are talking about here ;-)
If it is QUADRO, OCTO and LEAKSHIELD there is a solution with the X49 Insider version.
RobinXe
dimanche 20 février 2022, 17:29
In my case (don't want to hijack the thread, but it seems like my issue and the OP's may have the same cause) there's LEAKSHIELD, D5 NEXT, HIGH FLOW NEXT, and AQUAERO 6LT.
The issue also manifests in Aquasuite, in the form of the 'NaN' results for input in the Playground.
RBMDragon
mardi 22 février 2022, 09:41
I have gotten a response from aqua computer regarding the issue.
For me, it turned out to be an issue with the WinUSB driver, as the internal inputs and 'crosstalk' happened through that driver, but once Windows resets that, it loses connection.
They updated the insider firmware fix for the Leakshield, and now only the other devices have the problem.
So the fix they implemented resets the connection to the hardware devices (in this case the Leakshield) when it detects a WinUSB restart.
They are planning a X.50 insider update soon that should include more devices.
RobinXe
mardi 22 février 2022, 19:49
That's great info, thanks RBMDragon! In that case, I shall await the release of X.50, and the solution to all our woes!
