• 08.10.2026, 17:53
JOE02151@GMAIL.COM
after firmware update pump stuck at 2000rpm
mardi 5 avril 2022, 02:16
I just updated the firmware in my aquasuite software and my pump now only runs at 2000rpm, I have the d5next the highflow next and the aquashield
omgrubberduck
mardi 5 avril 2022, 02:43
Just had a similar issue on my D5 Next pumps after the firmware update to 1022. Going to the system section under the pumps on Aquasuite it said they were being controlled by aquabus. Well my aquabus port on my pumps is being used for RGBpx. On that screen changing it from RGBpx to the bus address option got the pumps running again, was then able to change it back to RGBpx and it's fine now.
mardi 5 avril 2022, 08:20
The buxfix relese for the D5 next fix is online now.
JOE02151@GMAIL.COM
mardi 5 avril 2022, 10:13
thanks that fixed it
TheMisfit
mardi 5 avril 2022, 18:22
Just joined looking for this answer, thanks!
Will update firmware tonight.
