• 22.11.2026, 08:01
khalita
Pump PWM Alarm
jeudi 14 avril 2022, 12:21
Hi all,
My pump would not start sometimes and causing the cpu to overheat. While I am still figuing out the cause to this, is there a way to set an alarm in Aquasuite when the pump is not running?
I am using alphacool DC-LT 2600rmp model which is totally silent. My case is a non see-thru ITX case so I cannot solve this by installing a flow indicator, nor do I have the space to install a flow sensor. Therefore I have no way to find out if the pump is running except to check in aquasuite manually. I want to see if I can set an alarm in Aquasuite so that it alerts me when the pump's pwm signal is 0 or below certain threshold.
Thank you!
Ce message a été modifié 1 fois. Dernière modification effectuée par "khalita" (14 avril 2022, 12:23)
Remayz
jeudi 14 avril 2022, 18:49
Can do, can do
Go to the playground, Outputs and create an output like that, to create a windows notification, a pop up, a sound.. whatever you prefer.
I made one that spams me notifications every 15s if the pump speed goes below xxx RPM
I've used 2600 rpm for the test, but pumps usually have a base speed of 800 RPM
So you could set a warning if your pump goes below that for example.
khalita
jeudi 28 avril 2022, 05:47
Can do, can do
Thank you! This is super helpful
