• 20.11.2026, 00:05
blackebaxter
new Build help. Leakshield wont test past 66mbar
mardi 24 mai 2022, 04:13
Hello. I have a 100ml utiltube D5 pump combo. Ive tried to run the test and let is run. The test times out after around 4 to 5 min. I cant seem to get the device to pull a negative pressure past 66mbar. I have taken the loop apart and torqued the seals as far as I can. Start the test again and it still wont pull past 66 mbar. I then unscrewed the leakshield from the tube and let it sit in open air while starting a test. It still reads around 66 mbar even tho the thing is not screwed on. I screwed the leakshield back on to the tube and then unconnected the loop from the D5 pump. I sealed the holes with tape so that only the reservoir was connected to the leak shield. Ran a new test and still only 66mbar. What am I doing wrong? What can I do to get the thing to run a proper test? ?( ?( ?( ?( Thank you
mardi 24 mai 2022, 10:05
Is the seal between ULTITUBE and LEAKSHIELD mounted in place?
blackebaxter
mardi 24 mai 2022, 18:04
I just checked there is no rubber seal between them. None came in the packaging. Where can I find the specs to order one?
Hufeisen
mardi 24 mai 2022, 19:40
You can buy a new seal here: https://shop.aquacomputer.de/product_inf…roducts_id=3866
The Seal is delivered with the Ultitube. Maybe the Seal is on the Ultitube Lid?
Or someone working at Aquacomputer forgot to put a Seal between the Lid and the Ultitube, so it was not delivered?
Then you can use the RMA process to get a seal: https://aquacomputer.de/rma-formular.html
Ce message a été modifié 2 fois. Dernière modification effectuée par "Hufeisen" (24 mai 2022, 19:55)
blackebaxter
mardi 24 mai 2022, 23:47
There is nothing else in the box. The rubber seal did not come with the unit. Just checked that to haver one shipped would be 75 euros in shipping. Go figure.
mercredi 25 mai 2022, 03:04
There is a POST on the German forum from someone who apparently also did not get the gasket that is supposed to come with the Utilitube. I wonder if there was a slip up at the factory and some units got shipped with no gasket.
mercredi 25 mai 2022, 11:35
Please contact the Support. We will send you an seal in an envelope.
blackebaxter
mercredi 25 mai 2022, 18:26
I have contacted support and was told that one would be mailed to me. I am extremely grateful for the the quick responses from this community and the support team. Thank you.
